Update again
Yesterday with a list of MOT fails in one hand, and a friend on hand, we decided to go for it, and get the PAS done
so basically nothing done for the mot, but i do have power steering
I basically started again with this one, the pump i had was missing several bits, the bracket, wireing, the relay PAS pipes ect ect, so we went to the scrappy and got a complete fresh system off of a Saxo with all the PAS pipes, wireing loom and relay, and with very little work, we had it all in in an hour
the main feed from the pump to the box is actually the saxo pipe, no cutting welding, just a nice clean straight pipe that runs over the cam/rocker cover
the return is not as high pressure so we used the Vitata return with some rubber pipe tweekage
on this pump, the resovoir was a divorced unit so that is up by the washer bottle
all in all, quite happy with it, i can now sit on my drive and turn from lock to lock using only the palm of one hand on the wheel
didnt take many pictures during as we just got on and did it, (it was bloody cold) however here are some of the fitted unit
