Will this engine fit??
Fwb2700
Re: Will this engine fit??
Post by Fwb2700 » Mon Dec 08, 2014 3:59 am
Now that sounds tempting. My f10a still runs and was ok for the few mins it was running
kiwizook
Post by kiwizook » Mon Dec 08, 2014 4:33 am
I'll buy your f10a if you remove it.
I looked at some g16 motors, but they are really pricey around here, you might pick up one cheap if you're lucky though
Fwb2700
Post by Fwb2700 » Mon Dec 08, 2014 5:14 am
Is your engine not running?
kiwizook
Post by kiwizook » Mon Dec 08, 2014 6:00 am
my engine is running sweet as mate, I fully rebuild it, apart from the main bearings, which were reasonably new and in good shape anyway. I swapped the head and fully rebuild it, all new gaskets, honed the cylinder bores etc, and also converted it to a su hs2 carb, which makes it really nippy. I just like to have plenty of spares for everything, especially things like starter motor's, alternators, manifolds etc. give me a bell if you're around here, and I can show you mate!
Fwb2700
Post by Fwb2700 » Mon Dec 08, 2014 6:05 am
Might be over that way round the Xmas New Years break. By any chance have you got any front leafs not completely flat lying around? Mine are inverted slightly
