Lwb samurai 1991 axles on sj413 1988
Is this a straight swap??? Guessing they are wider. Not sure of any other benefits or problems. Cheers.
Re: Lwb samurai 1991 axles on sj413 1988
Lwb samurai axles are exactly the same as SWB samurai axles.
You'll have to cut the spring perches off move each one 40mm inboard. And make sure you keep them as the same angle as the standard ones.
I would suggest fitting the 413 diffs into the samurai axles as well as they have a slightly lower ratio.
