Few more pics of those spectacular new arches, you can't see it too well in the pics but i've edged them with sum 4mm rod.
![IMG_0103.JPG](./download/file.php?id=991&sid=52b73d1335c68081e09218aa2450deed)
- IMG_0103.JPG (106.13 KiB) Viewed 12099 times
![IMG_0105.JPG](./download/file.php?id=992&sid=52b73d1335c68081e09218aa2450deed)
- IMG_0105.JPG (106.67 KiB) Viewed 12094 times
![IMG_0106.JPG](./download/file.php?id=993&sid=52b73d1335c68081e09218aa2450deed)
- IMG_0106.JPG (123.9 KiB) Viewed 12097 times
Thats it for the weekend i think now. Next weekend i'm gona try n get the fuel tank mounted and replace all the fuel lines. I still have a few small holes in the body work to patch. Other than that i think its a matter of going round with the grinder and tidying up some edges and a few bits to weld up properly.
Remaining to do:-
Fuel tank & lines
Rear wings
All lights & horn to fit
Tidy up welds / plating
Exhaust
Not sure how i'm gona do the exhaust. It wont pass MOT without it and technically i can't drive it to the exhaust place without MOT. If i go for an MOT and fail due to no exhaust, does that then allow me to drive to the exhaust place to have one fitted for a re-test?
Then.... Body filler, fibre glass, sanding, filling, bodging and painting
Doesn't look like much does it. So why do i still just have a garage full of bits? It's all sat together all the bits to go on are loosely bolted in place and yet i still seem to have various body panels and spare bits sat around.
