Post
by ferris » Tue May 18, 2010 11:11 pm
Ok, so after reading alot of crap on the web about setting up timing etc, iv come to a conclusion.
When i fit the new dizzy, i have to fit it so the roter arm so it is firing the right cyilinder at the right time. So if i set the bottom pully so the timing mark is pointing to 0 on the cam cover on both the engines, then fit the dizzy on the vit engine so the roter arm is facing the same direction as the roter arm on my 1.3 engine, it should be correct (if the engines are set up the same)
Does this sound right? Does this even make any sence?? Any thoughts would be appreciated
