Project Bodge
Re: Project Bodge
liking the body off the chassis look
wonder, if you are any good with any of the simple paint programes, could you please make a copy of the body on its side and show me where the mounting points are please... just for when i collect mine, i am looking to see if i can push it through mot before i do my welding.
cheers
cheers
Re: Project Bodge
Is this what you ment? Hope it helps.
Re: Project Bodge
Unfortunately there is no hidden workshop Just a rickety old gazebo that i have to try and put up every time it rains. Its a bloody nightmare, but should be worth it in the end.Gotta admit. I love the fact your doing this under a tarp, in what appears to be a field. Its as if u just stopped whilst out laning for an overhaul.
Is there a fully equipped workshop your just not showing in the fotos?
Re: Project Bodge
thats perfect thank you.
just a simple job to take of wings and front bumper?
than is it the brake pipes, acc cable, clutch cable and few wires to disconnect?
Re: Project Bodge
i can help with that one...
tony
tony
- bulkhead2_186.jpg (98.96 KiB) Viewed 8418 times
Re: Project Bodge
Ok update time again. Been pretty busy taking the old engine out, spliting and painting the spring packs, polly bushing every thing, putting on the new shocks and extended brake hoses. I also painted the chassis (i know its a bit unnecesary, but i got carried away)
Re: Project Bodge
hmmmm tasty
Keep up the good work
- Edweird
Re: Project Bodge
Overkill, yes, but it looks brilliant!ferris wrote:Ok update time again. Been pretty busy taking the old engine out, spliting and painting the spring packs, polly bushing every thing, putting on the new shocks and extended brake hoses. I also painted the chassis (i know its a bit unnecesary, but i got carried away)
Re: Project Bodge
looks top.. if its being rebuilt then why not paint chassis, just adds that finishing touch
