SUZUKI 413 FUEL TANK SENDER
basil
Post by basil » Wed Feb 11, 2015 9:13 am
Hi.
I need to replace the sender unit in my anus fuel tank ..can i get to it without removing the fuel tank ??????
thanks
timwilks13
SCUK Website Padawan
Re: SUZUKI 413 FUEL TANK SENDER
Post by timwilks13 » Wed Feb 11, 2015 9:21 am
For the sake of 4 bolts just drop the tank for easier access.
Post by ScottieJ » Wed Feb 11, 2015 9:21 am
Without cutting a whole in the rear floor no.
It's quite easy to drop the tank on an sj anyway.
basil
Post by basil » Wed Feb 11, 2015 9:24 am
Okay problem is the tank is full to the top as we were not sure how much was in there at any time
is there enough piping to allow lowering tank or do they need removing with loss of fuel ?????
thanks
Post by ScottieJ » Wed Feb 11, 2015 12:46 pm
some tanks have a drain bung on the bottom, it would be easier to disconnect the pipes and sender wires and completely drop the tank.
basil
Post by basil » Wed Feb 11, 2015 4:49 pm
Will put into garage when its warmer ....might be able to jiggle the wire connector if i can reach it in situ
grasping at straws i guess......no damn inspection plate to remove in the rear deck which would have been sensible of Suzuki.....
Guess it will be in order to carry on smoking my big King Edward cigars when i work on the fuel tank
jim
basil
Post by basil » Sat Feb 21, 2015 2:57 pm
Since replacing the faulty alternator the fuel gauge now reads correctly
Jim
Post by turbo-tom » Wed Feb 25, 2015 6:23 pm
What i normally do at times is take of the return line and fire the engine up an then it self pumps the petrol out :)
