1992 vitara fatboy
foubister56
1992 vitara fatboy
Post by foubister56 » Wed Feb 18, 2015 5:40 pm
Hi I have just bought a 92 vitara fatboy without power steering,I have also bought a power steering kit from one the same age.Can anyone tell me how big a job it would be to convert,thanks.
d_r_1989
Re: 1992 vitara fatboy
Post by d_r_1989 » Wed Feb 18, 2015 8:45 pm
Change steering box on drivers side chassis leg and install pipe work and resevoir. Bolt pump up to engine and tension belt. Tighten everything up fill with fluid and turn steering lock to lock when it's running. Job done
Rhinoman
Post by Rhinoman » Wed Feb 18, 2015 9:54 pm
If I remember correctly you need the lower part of the steering shaft as well because its a different length.
