Hi there.
The serpentine belt in my 2001 2.03 has started chirping.. where do you recommend me getting one from please and are there any tricks when fitting the new one it would be handy to know please. Thanks.
serpentine belt
Re: serpentine belt
Which belt?
Any motor factors should have one the correct length. Remove tension. Swap belt. Re-tension. Job done.
- Ginger_boy
Re: serpentine belt
as above but take some pics before you take it off for reference. As it can be a mind F..K when it seems to long
Re: serpentine belt
Careful not to over tighten new belt . Think its 9-11mm at 20lbs
