Grand vitara arch cover removal??
Jay18
Post by Jay18 » Mon May 04, 2015 7:57 pm
My arches, door trims and bumpers are in a bad state, lots of chips and scratches all over them and the bumpers have been resprayed badly with the wrong colour
So I need to know how to remove the arch covers and trims, I will probably spray the bumper on the car, but the rest need removing so I can clean any surface rust behind them before it gets any worse, then I can spray them pieces in my cellar..
Arches seem to unclip at the bottom and I guess they lift up, but not sure on the door trims...
Any help is hugely appreciated...
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
Re: Grand vitara arch cover removal??
Post by ScottieJ » Mon May 04, 2015 8:22 pm
I have a feeling the door trims are glued on?? I can't remember as it was a while ago that I stripped my old GV......some careful masking will save you removing them.
Jay18
Post by Jay18 » Mon May 04, 2015 8:31 pm
I think I can slide a piece of masking paper behind them, hopefully there is no rust behind them, I can see a little bit behind the arch covers that will get cleaned off and painted when I do the trims
Do you know where I can get the joining strip stuff that goes between the trim and the door? One piece seems to have shrunk and is now sticking out...
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
Post by dan_2k_uk » Mon May 04, 2015 8:35 pm
You will probably find some on a UPVC poor/window spares website.
They have loads of rubber trimmings like that. I got some to sort my front door at home as it was a bit draughty last winter.
Jay18
Post by Jay18 » Mon May 04, 2015 8:51 pm
It does look very similar to the rubber that holds the glass in my windows in the house
Will keep searching and see if I can find some
If the panels on the doors are glued on I'll probably just use some sealant and mask it and prime it, should do the job, about to order nearly £100 worth of stuff to do it all so hopefully it'll look sweet when it's finished...
Thanks for your help guys...
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
