Zooks in Malta
Re: Zooks in Malta
Post by twiss » Sun May 17, 2015 7:01 pm
courior
Re: Zooks in Malta
Post by courior » Mon May 18, 2015 2:07 pm
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
Re: Zooks in Malta
Post by ScottieJ » Mon May 18, 2015 2:59 pm
Looks good! You boys need to work on your flex and let some air out of those tyres though ;)
Some 4.16 tbox gears would be a good investment as well.
Re: Zooks in Malta
Post by turbo-tom » Mon May 18, 2015 3:33 pm
do you boys ever work? :lol:
courior
Re: Zooks in Malta
Post by courior » Mon May 18, 2015 3:49 pm
im not blaming my saharas for the complete mess getting up the second step.. its my crap standard length rear shocks.. they have less than 1 inch downward travel.. so my car usually has only 3 wheels on the ground when off roading lol
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
Re: Zooks in Malta
Post by ScottieJ » Mon May 18, 2015 4:02 pm
Some longer shocks next on the shopping list then. What pressure are you running? I would drop them pretty low for rocks tbh, it will help you climb without the need to bounce up.
courior
Re: Zooks in Malta
Post by courior » Mon May 18, 2015 4:12 pm
30psi at the moment.. mostly for fuel saving and lighter steering... but yeah softer would be a lot more comfortable on rutted ground. and better to climb rocks.
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
Re: Zooks in Malta
Post by ScottieJ » Mon May 18, 2015 4:33 pm
courior wrote:30psi at the moment.. mostly for fuel saving and lighter steering... but yeah softer would be a lot more comfortable on rutted ground. and better to climb rocks.
:shock: 30psi??? Bet that rides like a rock, standard pressure is 20psi, on larger tyres with thicker sidewalks it's often better to run less, especially on remoulds as they don't like to flex. Also you are possibly going to increase tyre wear at 30psi as you'll mostly be running on the centre of the tread.
I run on 18-20psi on road and drop them down to 10-12psi for off-roading unless it's laning or not very challenging terrain.
courior
Re: Zooks in Malta
Post by courior » Mon May 18, 2015 7:37 pm
I'll give it a go.. But I only have 45bhp to turn them. Its already a challenge keeping up with pedestrians lol
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
Re: Zooks in Malta
Post by twiss » Mon May 18, 2015 9:17 pm
Maybe you're the one that needs another engine in the back mate ;)
