out of controll
Re: out of controll
I only ever had cars so it sounds like wheel bearing gone so was going to swap the axles and do a full reconstruction of the old one or rebuild the one I have in the shed
Re: out of controll
pics of the ball joints
- FB_IMG_1432290098730.jpg (52.03 KiB) Viewed 5920 times
- FB_IMG_1432290103525.jpg (55.66 KiB) Viewed 5920 times
Re: out of controll
The ball joints look fine, could probably do with some new felts but those aren't even that important anyway.
Personally I would jack each side up, check for any play, give them a spin to see if they are noisy and just replace what needs changing, it's not hard to rebuild an Sj axle and you can easily just service one side at a time.
Re: out of controll
Thanks nice one will get on it this weekend
Re: out of controll
This thread tells you how to check and set up the wheel and kingpin bearings, if there's a bit of play in the kingpins you might be able to just remove some shims if there's any left, keep any that you take out for when you fit new kingpin bearings.
http://forum.suzukiclubuk.co.uk/vi ... =12&t=3182
Also you can download a service manual that shows all of the above a how to change bearings here
http://www.4x4.in.th/manual_sj413
There's also a guide in the "how to guides" section of the website ^^^
Re: out of controll
Nice one thanks
