Cant seem to find where to mount my clutch cable
gamble63
Post by gamble63 » Sun May 31, 2015 2:24 pm
Hey guys,having a bit of trouble with my clutch cable
we put the 1.3 in the 410, is there ment to be a bracket on the side of the engine to bolt the clutch cable onto? and can i swap the arm off the old gear box onto the new one so i dont have to change the cable end?
in the book it says there is a bracket but i just cant see it on either of the engines?
cheers guys :thumbup:
Re: Cant seem to find where to mount my clutch cable
Post by Jordi » Sun May 31, 2015 2:33 pm
Yeah. Should be a bracket on the side of the engine.
Not sure if 410 and 413 gearbox arms can be swapped though. Just try it.
Post by Darrell » Sun May 31, 2015 3:00 pm
Your looking for this.....
clutch cable bracket.jpg (34.01 KiB) Viewed 5974 times
Post by ScottieJ » Sun May 31, 2015 4:59 pm
I might have one of those brackets in my spares, will have a look for you.
gamble63
Post by gamble63 » Sun May 31, 2015 6:49 pm
ahh that would make a lot of sense, i dont know how ive managed to loose one off the 1ltr and the 1.3ltr .
Scottie if you did have one would you be up for selling it to me and the 2 bolts if you have them?
then im just short one shitty rubber mount for the body and it should be up and running :)
cheers for the help guys
Post by ScottieJ » Sun May 31, 2015 11:33 pm
:doublethumbs: will dig one out.
Which body mount do you need? Probably got one of those as well.
gamble63
Post by gamble63 » Mon Jun 01, 2015 9:28 am
Awesome just let me know and i can send money over for it.
im literally just after one of the rubber spacer spacer type bits that sits in the metal cup which bolts under the chassie onto the other side of the body mount bolt. will take a picture when i am home unless you managed to work out my shite description.
edit** in this picture its the ones that are second row from the top:
http://www.ebay.com/itm/SUZUKI-CHASSIS- ... 1216326041
cheers :)
