it helps that when I strip and SJ I just throw all the nuts n bolts in a box....so I pretty much know where every one goes...I have stripped and rebuilt quite a fewdan_2k_uk wrote:Yet again.....ScottieJ wrote:That there would be a fuel tank/guard mounting bolt
I showed my dad the bolt as well and he got it straight away
- Tramp
Haha, the bottom of the canal..... Or underneath my samaurai! They were a pain to get out so I've bought some stainless replacement bolts (or setscrews if I'm being anal)Darrell wrote:"Technically your incorrect anyway, it's a setscrew with washer and spring washer but I'd like to know where it's from"
Bottom of a canal looking at it
If I was a moderator, I'd ban you from this game! You always get it right!!!
At least I let others have plenty of guesses first
- Tramp
Yeah there is that, which is fair enough! So I guess it's your turn, go on then, have you got a picture for us?ScottieJ wrote:At least I let others have plenty of guesses first
Just where in the vehicle will do.....this could be a challenging one? Then again it might not be.
Is it on the back of the instrument cluster?
- Tramp
It looks like a home made lights on, ignition off, door open(?) buzzer circuit - we had the instructions in the DIY section for a bit didn't we? If it is...... I'd guess in the speaker pocket in the drivers side footwell?
A diode and a 1.6K ohm resistor
- Tramp
There's a transistor too.....Darrell wrote:A diode and a 1.6K ohm resistor
Maybe it's an Op Amp circuit?
