Propshafts
Propshafts
What other prop shafts will fit an Sj? As need stronger ones because I am running 38" tyres, cheers
Re: Propshafts
If the gearing is set up correctly there should be no need to upgrade propshafts.Modified wrote:What other prop shafts will fit an Sj? As need stronger ones because I am running 38" tyres, cheers
Custom props are the only option other than standard. Shortened Toyota props are common swaps.
Re: Propshafts
Are you building this truck from scratch?
