hi are sj410 prop the same as sj413
I have a spare truck in my garden but the prop is like a solid bar so would it be a older truck or newer
sj410 and sj413 parts
Re: sj410 and sj413 parts
A solid bar?
Doesn't sound right. There are different flange sizes on some SJs / Samurais. Not sure which is which but there is a small flange and a big flange.
Other than that and 410 props being slightly longer they are all just about interchangeable.
Sounds like an early 410...the bolt pattern is different I think.
ok thanks is it worth me changing the uj bearings myself
I think the prop bolt patterns are the same but the center bit is a different size...
There is a guide in the DIY section about how to change the Universal Joints
But near me I have a guy who changes them for €10 (excluding the part) so I don't bother any more
For that sort of money, its worth sending props from the homeland to you twiss to get u/j"s done. You seem to have settled in well over there.
I like it here everything is cheap and theres lots of fellow Zookers!
Even non off roaders, there's more random people driving around in Zooks and Marutis
