sj413 with 1.6 engine. what alternator to use?
Josh-holden
Post by Josh-holden » Sun Aug 30, 2015 1:48 pm
i have a 413 sj, it has the 1.6 vitara. I need an alternator for it, is there a uprated one? where's the best place to get one from? its got the ribbed aux belt not the v belt
Re: sj413 with 1.6 engine. what alternator to use?
Post by Jordi » Sun Aug 30, 2015 9:53 pm
I just run a standard Vit alternator to match the engine.
Josh-holden
Post by Josh-holden » Wed Sep 02, 2015 2:55 pm
ok, does anyone know what amp the alternator should be 1.6 vit engine? 50 or 70?
Post by ROBBIE » Wed Sep 02, 2015 8:25 pm
I ran the 1.3 alternator as it matched the plug
Josh-holden
Post by Josh-holden » Thu Sep 03, 2015 10:00 am
mine has the round plug with the ribbed belt. i think its 50 amp. i think the part number is LRB00125. these are about £135. do you know anywhere i can get it cheaper or a second hand one?
Josh-holden
Post by Josh-holden » Thu Sep 03, 2015 10:05 am
also, would i be able to run the 70amp alternator?
Post by twiss » Fri Sep 04, 2015 11:22 pm
Just to add, I would recommend using the alternator with the internal fan, kinda like this
Rather than an external fan like this
The external fan seems to pick up water and spray it everywhere
Jayanson1997
Post by Jayanson1997 » Sat Oct 17, 2015 10:10 pm
1.3 or 1.6 either one will work apparently
