sj413 with 1.6 engine. what alternator to use?
- Josh-holden
i have a 413 sj, it has the 1.6 vitara. I need an alternator for it, is there a uprated one? where's the best place to get one from? its got the ribbed aux belt not the v belt
Re: sj413 with 1.6 engine. what alternator to use?
I just run a standard Vit alternator to match the engine.
- Josh-holden
ok, does anyone know what amp the alternator should be 1.6 vit engine? 50 or 70?
I ran the 1.3 alternator as it matched the plug
- Josh-holden
mine has the round plug with the ribbed belt. i think its 50 amp. i think the part number is LRB00125. these are about £135. do you know anywhere i can get it cheaper or a second hand one?
- Josh-holden
also, would i be able to run the 70amp alternator?
Just to add, I would recommend using the alternator with the internal fan, kinda like this
![Image](http://contentinfo.autozone.com/znetcs/product-info/en/US/wwd/12063/image/2/)
Rather than an external fan like this
![Image](http://img.weiku.com/waterpicture/2011/10/29/16/Kia_alternator_1_1232_01HI_auto_parts_634571109206784082_5.jpg)
The external fan seems to pick up water and spray it everywhere
1.3 or 1.6 either one will work apparently
