its been a while, but we have a new snag!
robbie1985
Post by robbie1985 » Mon Sep 07, 2015 8:29 pm
The last week or so i have been experiencing a bad vibration that sounds and feels as though its coming up from underneath the seats, so i am thinking that it could be coming from the transfer box or drive shaft. I've checked the transfer box mount and it doesn't appear to to have any excess play in it which leaves me thinking that its drive shaft/diff.
do you guys have any ideas as to what else it could or have had the same problems?
cheers
Re: its been a while, but we have a new snag!
Post by ROBBIE » Tue Sep 08, 2015 10:05 am
Ujs on prop shafts ok?
robbie1985
Post by robbie1985 » Tue Sep 08, 2015 3:56 pm
As far as I can tell they are alright, how would they act if they where worn? Would it just be excessive play in the prop shaft?
robbie1985
Post by robbie1985 » Tue Sep 08, 2015 4:48 pm
Just checked the uj's on the driveshaft and there is around 1 mm of play going into the diff so I'm thinking that's the problem?
Post by ROBBIE » Tue Sep 08, 2015 11:10 pm
I had one uj go that I didn't notice until it was beyond repair, and another that caused a nasty vibration
Post by donkeychomp » Wed Sep 09, 2015 12:42 am
There are 3 transfer box mounts..I'd have another look. Have you tried tightening them? Does the rubber bushes on them look worn?
robbie1985
Post by robbie1985 » Wed Sep 09, 2015 7:55 am
Cheers donkeychomp, I'm gonna get the car up on a ramp tomorrow so I can have a better look. And Robbie I think I might chat to my parts guy and see if he has a drive shaft I can borrow, before I spank £60 on new uj's. I noticed this morning that I can't feel the vibration through the gear stick but the low range stick was vibrating, so i'm swinging towards the uj's or at least the rear on as it has the most play in it.
robbie1985
Post by robbie1985 » Thu Sep 17, 2015 8:16 am
So I replaced both the uj's on the drive shaft and although the harshness and frequency of the vibration and noise has been reduced dramatically it still persists. Hawever I am almost 99% sure that it is coming from the rear of the car as the new ujs have tightened all the drive up. Any ideas where I can look now? I'm thinking of draining the diff and pulling both hubs off to check for wear. Although I did notice that the drivers side rear spring is sagging I wonder if that may have anything to do with it? I doubt it though. On the plus the new uj's have made a massive difference as the olds ones were well shot.
Post by ROBBIE » Thu Sep 17, 2015 8:32 am
Could be the bushes on the axle are shot
robbie1985
Post by robbie1985 » Wed Sep 30, 2015 8:38 pm
Does anyone know a good place that I can order poly bushes for the rear diff? Need the set to replace the bushes with, figured I'd may as well upgrade them at the same time
