Switched live for a 12v cigarette socket?
Phillips321
Post by Phillips321 » Wed Apr 20, 2016 10:22 pm
Hi guys,
Just got my SJ410 1986 and have had a good look over it.
There is no radio and no 12v cigarette socket. I'm looking to wire in a 12v socket but want it only to come on when i turn the engine on, ACC?
Basically i'll be using it for running a high amp spotlight and occasionally a usb charger.
What are the best wires to tap into for this?
Many thanks
Re: Switched live for a 12v cigarette socket?
Post by ScottieJ » Wed Apr 20, 2016 11:16 pm
Look for a wire that is black with a white tracer under the centre of the dash, usually one floating around somewhere for the cigarette lighter and stereo.
Phillips321
Post by Phillips321 » Wed Apr 20, 2016 11:47 pm
ScottieJ wrote:Look for a wire that is black with a white tracer under the centre of the dash, usually one floating around somewhere for the cigarette lighter and stereo.
I found that one but it's live all the time? Should it be? It was wired into an iso plug so definitely for a radio.
Post by ScottieJ » Thu Apr 21, 2016 11:53 am
Are you sure that wasn't a wire that was white with a black tracer? That one should be live on the first click of the ignition aka acc, however it shouldn't be permanently live.
Phillips321
Post by Phillips321 » Sat Apr 23, 2016 8:08 pm
Magic, finished it now. USB goes to ACC and 12v direct to battery (with a 25A fuse)
SherwoodNash
Post by SherwoodNash » Sat Apr 23, 2016 8:33 pm
Very neat :thumbup: and they won't get in the way of the clothes peg ;)
