Changing the head light bulbs... basics???
Phillips321
Post by Phillips321 » Sun Apr 24, 2016 3:17 pm
Hi guys,
Anyone got any info on how to change the headlight bulbs? I'm hoping to replace them for some LED ones so the light is white (better for spotting eye shine whilst hunting). The only issue is i can't remove the old ones to check what bulbs they are!
Any idea on how to remove them? Maybe a quick video or a few pics would help me...!
Thanks in advance
Re: Changing the head light bulbs... basics???
Post by twiss » Sun Apr 24, 2016 4:01 pm
On the old 410s they have sealed unit headlights and you can't take the bulbs out.... you will have to fit some aftermarket ones, or samurai headlights... sorry!
Phillips321
Post by Phillips321 » Sun Apr 24, 2016 5:09 pm
So how do I remove the unit? And are there any directly swaddle models from other vehicles? Looks like some sort of catch here?
I guess if the bulb blows i need to replace the entire light???
SherwoodNash
Post by SherwoodNash » Sun Apr 24, 2016 6:00 pm
My Jap '87 had original headlights (I might be wrong?) with removable bulb unit , here's some pics if it helps :D
Post by ROBBIE » Mon Apr 25, 2016 10:47 am
Phillips321 wrote:So how do I remove the unit? And are there any directly swaddle models from other vehicles? Looks like some sort of catch here?
That looks like a separate bulb in there
Post by twiss » Mon Apr 25, 2016 11:30 am
Yep Robbie is right thats just a twist off one.... my bad I think it was the 83-84 that had the sealed unit.
Just make sure you get the right bulb fitting as it will probably be a P45T
