KJA cut n shut
stevepsj413
Re: KJA cut n shut
Post by stevepsj413 » Fri Jan 29, 2016 6:02 pm
andyrew wrote:They look awfully like the caps i sold on ebay recently :lol:
Now that you mention it im sure the seller was andyc or something similar! At least you know they've gone to a good home! :D
stevepsj413
Re: KJA cut n shut
Post by stevepsj413 » Sun Feb 07, 2016 7:30 pm
Just done the power steering conversion on the kja, I used the guide on here and it was 100%. I used the full vitara setup, steering box, pump and pipework, apart from the flow pipe, I used a shorter piece of flexi pipe for this. Then i made a wedge out of some 4.5mm plate, made a new rad bracket for the drivers side and notched a piece out of the passenger side to clear the pump, had to shorten the steering bar that goes from the box to the bulkhead. It seems to clear everything by a couple of mm. Only thing left to do is make a bracket for the reservoir bottle, at the moment its cable tied to the jack!
ianedwards
Re: KJA cut n shut
Post by ianedwards » Sun Feb 07, 2016 7:39 pm
nice, i used a jimny box on mine, but it makes it a lot nicer to drive. :)
Ian. :)
stevepsj413
Re: KJA cut n shut
Post by stevepsj413 » Sun Apr 17, 2016 8:13 pm
Still loving every minute of this pickup, still running well. Fitted a different speedo cluster the other day, the KJA now has a rev counter, very posh I know. Big thanks to andyrew for that. All i need now is a working clock and the luxury will be spectacular, ha ha.
Re: KJA cut n shut
Post by andyrew » Sun Apr 17, 2016 8:48 pm
Sweet, glad the cluster worked :thumbup:
SlimGrim
Re: KJA cut n shut
Post by SlimGrim » Sun Apr 17, 2016 11:06 pm
Very tidy :doublethumbs:
___________________
stevepsj413
Re: KJA cut n shut
Post by stevepsj413 » Tue May 03, 2016 4:25 pm
As you might of seen from my new build thread, i've got another kja. Its a long way from the road and it had a few nice parts on it that it seemed a shame to leave around the workshop getting covered in overspray etc.
So here they are fitted to kja number 1. Stainless rear bumper with better height tow hitch, stainless side steps and a stainless a-bar behind the cab. Also put the full stainless exhaust system on her, its a lot quieter than the cherry bomb was. Just need to fit the original chrome mirrors now!
Re: KJA cut n shut
Post by twiss » Tue May 03, 2016 11:18 pm
Im liking the rollbar... but the side runners look a bit low!
stevepsj413
Re: KJA cut n shut
Post by stevepsj413 » Tue Oct 04, 2016 7:14 pm
Its been a while since I updated this. The pickups still going strong. Had to fit a vitara radiator to it, when we had that warm weather the temp gauge seemed to be getting a little high for my liking. So i made a few brackets and fitted the 1.6 rad I had, seems to run a lot cooler now, haven't seen the temp gauge go past half way since fitting the new rad.
Then I got a front bull bar from ebay and fitted that along with some retro square spot lights I had. Then I decided to fit the headrests I got with the bedford rascal. They looked the same as KJA ones but were infact 20mm too long, so out came the grinder and the welder. Just on the lookout for some seats/doorcards with the same material as the main seats now so that my interior trimmer (my mum) can re-trim the headrests to match the seats.
Also found a transfer box bash plate in the back of my yard that I'd made a while back and never fitted, had to trim a little bit off to clear the back of prop brake but thats all done and fitted now, and lastly I put the chrome mirrors on her.
Drivers side rad bracket
Passenger side bracket
Bull bar with spots
Bull bar with spots
Headrest brackets, top how they came, bottom -20mm
Headrests fitted
Headrests fitted
Posing
Posing
Re: KJA cut n shut
Post by Jordi » Tue Oct 04, 2016 8:39 pm
Looks tidy bud. The side step / bars look a bit odd, presuming they are a proper step?
