Buzzing noise from large heat sync under passenger side dash
SlimGrim
Post by SlimGrim » Thu Sep 08, 2016 7:43 pm
Under the dash above the passenger side footwell is a large round aluminium heat sync, which has recently taken to clicking really fast when the engine is running until I turn the lights on at wich point it stops, the noise returns when I turn them off again, any ideas on what this is and why it could be doing this?
___________________
SlimGrim
Re: Buzzing noise from large heat sync under passenger side
Post by SlimGrim » Thu Sep 08, 2016 7:45 pm
This
___________________
Post by twiss » Thu Sep 08, 2016 8:14 pm
Think its the dim dip relay. Should be OK to just unplug it
zook123
Post by zook123 » Fri Sep 09, 2016 9:02 am
It's your AirBag ECU, or Flux Capacitor :)
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
SlimGrim
Post by SlimGrim » Fri Sep 09, 2016 10:44 am
I have an airbag!?
___________________
zook123
Post by zook123 » Fri Sep 09, 2016 10:50 am
haha, nope! I do. If it works or not is another question!
Post by donkeychomp » Fri Sep 09, 2016 9:24 pm
I have the same issue with my LJ and the noise stops when I brake. Why it does this is a complete mystery.
Post by dan_2k_uk » Fri Sep 09, 2016 10:20 pm
Dim dip unit. Unplug and chuck it.
SlimGrim
Post by SlimGrim » Fri Sep 09, 2016 10:25 pm
is it useless or should i replace?
___________________
Post by ROBBIE » Sat Sep 10, 2016 2:56 am
No need to replace
