Twiss' LWB Build
Re: Twiss' LWB Build
Got the block in sort of the right place today... missing the engine mount brackets though.
Spins free and cylinder walls aren't scored so might be OK
The head however is a different story so the search for another will begin!
Mostly dismantled the head, apart from the valves... Everything in there looks OK, mostly the mating surface that is shit
- 15857557_10158254350505122_1255944074_o.jpg (319.79 KiB) Viewed 8140 times
A few pics from today... had to cut all the bolts for the roof support/rollbar... chopped a bunch of rust out (still more to go) ... started preparing the rear passenger side wheel arch for vl
Got about half of the first wheel arch finished... pics to follow when its done.
Got the "carbs" i ordered today, turns out they are actually throttle bodies... injection 410 it is then...
Nice orange injectors
Inside
TPS
Inside
TPS
- donkeychomp
R6 throttle bodies mate
- donkeychomp
Wow, you sure aren't doing things by halves are you? Nice choice buddy!
Looking good I must say!
Is this going to be a slightly longer version of your SJ?
Is the rear going to be done out like a limousine, I know you like your comforts!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Nice, don't think i'v ever seen a LWB before....whats the wheelbase on it mate?
Yeah its going to be a slightly longer and slightly turbocharged version of mine
Will probably get a 1.6 16v eventually!
Wheelbase is 93.5" I think? Samurai is 80"
