side exit exhaust ?
farmerben
side exit exhaust ?
Post by farmerben » Wed Dec 08, 2010 8:38 pm
just wondered if anyone had fitted a side exit exhaust ???? if so was it hard???
1992 Suzuki SJ 413 samurai,TURBO,Webber carb,2" calmini shackle reversal kit,32mm wheel spacers,maxxis 235/75/15 mud tires,vitara alloys,swift gti interior,1"lift springs,heavy duty transfer box mounting bracket.
1986 land rover 110 ,boost alloys,bfgoodrich mud terrains,a bar,spot lights,
Henry
Re: side exit exhaust ?
Post by Henry » Wed Dec 08, 2010 10:29 pm
The first backbox is pretty much in line with the seats, a bit of bending and welding and it would be a side exit. pretty easy :twisted:
Post by ScottieJ » Thu Dec 09, 2010 8:58 am
Just be careful about where it comes out, you don't want it somewhere that you can crush it when out offroading
Post by twiss » Thu Dec 09, 2010 12:09 pm
Yeah like scott says, with the rear exhaust, most of the pipe is tucked up inbetween the chassis rails...
If it's coming out the side, it's going to reduce your clearance on that side, so be careful
Post by Jordi » Thu Dec 09, 2010 1:58 pm
As above i think side exit exhaust may be vulnerable. Best conversion in my opinion (and cos i have one) is a stack.
farmerben
Post by farmerben » Wed Feb 23, 2011 9:27 pm
thanks for the advise !
farmerben
Post by farmerben » Thu Mar 10, 2011 9:52 pm
this is what i had in mind its a Porsche exhaust tip
Porsche exhaust tip
Porsche exhaust tip
DSC_0396 [50%].jpg (117.59 KiB) Viewed 7588 times
4eye
Post by 4eye » Thu Mar 10, 2011 10:04 pm
looks cool 8-) ..............but veeeeeeeeeeeeeeeery sqashable!!!!!!!!! :thumbdown: :shock: :thumbdown:
my ride.........:4eye:
farmerben
Post by farmerben » Thu Mar 10, 2011 10:17 pm
ye thats what i was thinking but i don't go hardcore off roading so thought it might be ok :S
Post by ScottieJ » Thu Mar 10, 2011 10:35 pm
I'm not sure if that exhaust mount will pass the MOT or last very long, maybe the first 5cm of movement :lol:
looks good, it should be fine there as long as your careful.
