2" Body lift
- felstmiester
2" Body lift
Wasn't sure where to put this fellas so its here.
I wanna do a 2" body lift but noticed the kits on ebay have 8 blocks when i'm sure there's 10????
Also, will a 2" body lift only allow me to get a set of 235/75/15's on??
Re: 2" Body lift
Yes there are 10 body mounts. If your looking at the cheap kits off flebay they come with long bolts instead of sleeved bolts. As I understand it they are a complete pain in the ass to fit and require cutting holes in the floor. After what I've read it's well worth paying the extra for a good kit.
- felstmiester
Re: 2" Body lift
Either way your going to have to cut the orriginal threads off the body to be able to put the extended one's in surely?
The nylon one's on ebay look ok to me, its just that in the pic there's 10 lift blocks but in the listing it says 8.
I've got the tyres on now with clearance in the arches. only issue is the front tyres rub on the leafs when on full lock. Suppose it might give me trouble when im off road with the tyres rubbbing the arches maybe. In the mean time i'm gonna fit wheel spacers n see how it goes.
Re: 2" Body lift
hi, i have those size tyres on mine. i have a 2 inch body lift with up graded springs giving about another 2 inch's. my rear wheels are a pair of rhino rays offset's, fronts are standard but with spacers. doesn't rub on full lock and only just touch's the arch's when going over the real rough stuff.
have got a pair of reversed rims to go on the front but not fitted them yet.
hope this helps.
Kev
hope this helps.
Kev
Re: 2" Body lift
I would get a bits for vits one, they have 10 lift blocks and use custom bolts.
http://www.bits4vits.co.uk/store/samura ... d_304.html" onclick="window.open(this.href);return false;
you can also limit the steering as a last resort if you cant stop the tyres hitting the leaves pretty easily
- felstmiester
Re: 2" Body lift
Sorted. I've made a set of body lift blocks with special studs that thread on the existing ones to save all the hassle. Spacers are on wheels are on and no rubbing at all. One drawback with fitting the big tyres tho is it sacrifices the low gearing and i now find I have to keep on the clutch when in deep mud or water to keep the revs up.
- felstmiester
Re: 2" Body lift
Ha wheels are worth more than the the zuke its self
- banana lift 1.JPG (101.57 KiB) Viewed 12349 times
- banana lift 2.JPG (100.59 KiB) Viewed 12349 times
Re: 2" Body lift
do you need to extend the fuel filler neck or steering etc was thinking of lifting the body on my santana
1987 SJ416 lwb pick up, vit 8v engine on su carb, 1.0ltr trans box, spoa conversion, twin winch, full roll cage, 31x10.50R15
1990 SJ410 santana soft top very much standard 1 0wner from new 50,000 mile on clock in need of a welder and TLC!!!
