parrots trak
- Can I have a tow
Re: parrots trak
well i empted my truck and i knew i could smell diff oil,it leaked out of the front diff into the foot well,my tyre looks bad and i also started on the front short bolt on drive shaft so i will have bolt on ones both side's
- Can I have a tow
Re: parrots trak
welded up my bolt on shaft adaptor to night,just got to make up a bolt on shaft out of my spare shafts and brace the bracket i had to cut up then paint the axle and its ready to bolt on the truck.
tack'd togeather
pre heated in the oven
first run of weld
secound run of weld on the outer of the first one but not all the way around due to the bolt heads
3rd run on the inside of the first weld
4th run over the top of the secound and 3rd weld
a quick clean up to get rid of any splater
tack'd togeather
first run of weld
- Can I have a tow
Re: parrots trak
fitted
painted
before anyone says it its the only colur i have left
painted
- Can I have a tow
Re: parrots trak
finsih'd the front axle mount today,welded up my other auto hub and made a adjustable panard rod.
4x4steve got me into useing cad
- Can I have a tow
Re: parrots trak
standard panard rod
cut up adjustable lr one
cds tube
standard one cut in half
cds next to the std rod
std one axle end push'd into the cds tube
lr adjustable end push'd into the other end of the cds
- Can I have a tow
Re: parrots trak
some flat bar to brace the end
