MMMMMMMmmmmmmmm Shiiiiiinnnyyyyyy
http://www.aqualu.com/suzuki-samurai-bodies.html" onclick="window.open(this.href);return false;
I want I want I want!
Re: MMMMMMMmmmmmmmm Shiiiiiinnnyyyyyy
Thats mental. How much are we talking for one of them bad boys?
As with all shiny things! EXPENSIVE!!!
LWB tub is $3483.00
Dont know how much the SWB tub is though, but probably a little bit cheaper as there is less aluminium
LWB tub is $3483.00
- dominic
- Can I have a tow
Mmmmm Yes oh yes.
Very nice, i have one, ops just two problems ...... lack of cash to buy, and to get it shipped over. DAMN IT.
So people just might go and after seeing such lovely aluminium body... NOT ME .
i just need a fag.
Dom
i just need a fag.
Dom
Currently Drive
SJ 410 Q 1985 (GREEN)
VITARA GL+ 2017 (SILVER)
no more tin worm
There's a pretty major problem with this though, one that would make me prefer a brand new steel version
Corrosion of aluminium into steel, as soon as a steel bolt or component is connected to the ali, it will seize solid!
Plus how do you earth the electrical system to body? It would have to go straight to the chassis.
Christoff wrote:There's a pretty major problem with this though, one that would make me prefer a brand new steel version
yep that could be a problem over a long period of time but you could always use some aluminium bolts, it shouldn't really be a problem though, it takes a long time for steel and aluminium to seize together. What are all the bolts in your Engine block and head made out of?
also not a problem aluminium is more electrically conductive than steel, its actually one of the best electrical conductors out of all non precious metals, however if the surface is anodized then the surface will not conduct electricity.
- Tramp
A lot of machinery cables are made out of aluminium now as its cheaper than the old fashioned alternative although they do require a greater CSA (cross sectional area) and they don't bend as easily, also you need different ferrulesScottieJ wrote:[
