nasty banging and grinding
Re: nasty banging and grinding
Post by Darrell » Thu May 19, 2011 9:46 pm
How did you manage that :er: . The back plate stops the bearing coming out. Has it only got the inner bearing race left on it.
Rear wheel bearing diagram.jpg (365.94 KiB) Viewed 4521 times
Post by Darrell » Thu May 19, 2011 10:31 pm
I found this photo in the disk conversion writeup. I guess some models have a seperate retainer plate. Good idea, mine I had to disconnect the hoses etc. I haven't seen a manual showing this seperate retainer either :er:
Edit - managed to find a diagram - said it was for the santana. Knew I'd find a diagram sooner or later :oops:
Christoff
Post by Christoff » Thu May 19, 2011 11:25 pm
Some quality information there mate legend!
I did buy a wheel bearing months ago but never fitted it because i havnt got a slide hammer. Think i paid £50 odd quid for it which i thought was a bit steep.
Jamie_stafford
Post by Jamie_stafford » Fri May 20, 2011 7:10 am
That pic is the same as mine with the seperate retainer plate, it makes the job so much faster :thumbup:
Suzuki, because life's to short to be fixing landrovers!
Post by ScottieJ » Fri May 20, 2011 9:09 am
Jamie_stafford wrote:i just jacked up the drivers side wheel and gave it a spin, sounded nasty so out came the half shaft and its the wheel bearing! i shold of looked a bit closer when it was all out before. thanks for all the help chaps
:good: glad you found the problem matey
Post by Darrell » Fri Jul 01, 2011 10:53 pm
£50 is a rip off price. You can get original Koyo bearing, retainer and oil seal for less than £30 http://www.bigjimny.com/store/index.php ... -/p_5.html" onclick="window.open(this.href);return false;
A SKF bearing is a tenner plus vat for probulary the best brand bearing you can get.
