Rusting arches
Turb()
Rusting arches
Post by Turb() » Sat May 21, 2011 12:44 pm
Right nice sunny day today so I thought I would have a look at the SJ.
I noticed the wheel arches were starting to rust slightly under the plastic spats so I pulled them all off to get a proper look at the damage.
Its not good....
They are rotting away underneath and even starting to create holes in a couple of my wings! :yuk:
Whats the best thing to sort it out? I dont have access to a welder so to get any wleding would probably cost a fortune....
Could I cut the lips off that hold the spats with an angle grinder, treat any remaining rust then fibreglass over the holes?
Lil_Beastie
Re: Rusting arches
Post by Lil_Beastie » Sat May 21, 2011 6:49 pm
Got any pictures?
Turb()
Re: Rusting arches
Post by Turb() » Sat May 21, 2011 8:07 pm
Turb()
Re: Rusting arches
Post by Turb() » Sat May 21, 2011 8:08 pm
I'm thinking grind the lip off, treat the rust with some rust eater, fibreglass and paint over it and then make up some bigger arches to bond/rivet on
Re: Rusting arches
Post by Edweird » Sat May 21, 2011 11:04 pm
What you've got looks like the same as mine, in the same places. I'd like to see how you fix it. :D
Lil_Beastie
Re: Rusting arches
Post by Lil_Beastie » Sun May 22, 2011 10:49 am
Virtual Lift? Removes rust and increases upward tyre space. :smokin:
You may recognise the bloke doing it for me... :guns:
Turb()
Re: Rusting arches
Post by Turb() » Sun May 22, 2011 3:56 pm
Aye but requires welding lol. Any idea how the lip that holds the plastic spats is bonded to the body?
I dont want to try hacking away at it with an angle grinder and take big chunks out of the already thin bodywork....
Lil_Beastie
Re: Rusting arches
Post by Lil_Beastie » Sun May 22, 2011 4:19 pm
Its spot welded. Once you rub away the dirt and rust you should be able to see little circle indents in the metal against the bodywork.
If you try and grind them all out, it should come off. Or if its rusty enough behind the whole thing may rip off :mrgreen:
parrotveasey81
Re: Rusting arches
Post by parrotveasey81 » Sun May 22, 2011 5:39 pm
Turb() wrote:Aye but requires welding lol. Any idea how the lip that holds the plastic spats is bonded to the body?
whats your location,welding dose not half to cost lots if you know the right people :thumbup:
Re: Rusting arches
Post by ROBBIE » Sun May 22, 2011 9:17 pm
i was goin to say as Lil_Beasties pic shows havin a Parrot helps :lol:
