filling gearbox oil
Re: filling gearbox oil
Post by ScottieJ » Tue May 24, 2011 10:37 am
Eeeerrrrrrrrr more than enough, think you need to drain some its 1.3L :lol:
Smalljeep
Post by Smalljeep » Tue May 24, 2011 11:08 am
too much oil is better than none i suppose.
although i bet someone will say its worse
1991 Suzuki Samurai with 1.6 8v engine
2002 Peugeot 406 HDi 110 Executive
Henry
Post by Henry » Tue May 24, 2011 8:26 pm
It is worse, and the wrong oil is also bad,
A story.
Our JD6610, just serviced it and put universal oil all round. Next thing no drive in any gear. So rev it up flat out for 10 mins to get the vacume, next thing we have drive, but a horrible noise in between packs (6 boxes with 4 packs in each box)
Get the specialist out, using oil that is twice as thick, so i hope thats the problem because gear boxes aint cheap! :bawling:
Smalljeep
Post by Smalljeep » Tue May 24, 2011 10:26 pm
ah the oils the correct type, its what the motorfactors suggested and the same as the red bottle as shown earlier.
Anyhow its away to the mechanics tommorow. Its getting an engine oil change, sump and rocker gaskets replaced, the gearbox oil sorted, clutch set right and the coolant system looked at. It heated up rather rapidly i believe the the systems airlocked or the thermostat is defective. (but i have a supply of a spare rocker cover, sump, fuel pump, water pump, thermostat) so theres should be no problems.
Smalljeep
Post by Smalljeep » Tue May 31, 2011 1:14 pm
is this the filler plug on the left?
ferris
Post by ferris » Tue May 31, 2011 6:12 pm
No, its this one on the back of the gearbox. (Sometimes its a normal bolt instead of a square job.)
Smalljeep
Post by Smalljeep » Tue May 31, 2011 10:21 pm
ah that explains why nothing come out, ill have a go at draining it.
thanks
Post by Edweird » Thu Jun 02, 2011 11:52 pm
I found that ratchet drives (1/2 inch etc.) usually fit in those pretty well. Is that what they're made for?
Henry
Post by Henry » Fri Jun 03, 2011 7:35 am
Yes they are made for the ratchet drives. Ive welded nuts to the end of mine as i HATE those stupid little square drive things, whats wrong with a simple bolt?
Post by Edweird » Fri Jun 03, 2011 12:13 pm
My brian is telling me that they're less likely to shear?
