started my head rebuild yesterday!
Well i finally thought it was time to rebuild the head on my zuke as the valve stem oil seals are on there way out and she was smoking like a trooper! nice and simple job eh! but why oh why did suzuki decide to use crosshead screws to bolt down the rocker shafts! whats wrong with a good old bolt that is nice and easy to remove!
Re: started my head rebuild yesterday!
So they could make even more money when you have to take it to them to repair your bodged attempt at removing thembut why oh why did suzuki decide to use crosshead screws to bolt down the rocker shafts!
You can go fast, I can go ANYWHERE
True, luckily I only destroyed 2 of them
off to my local suzuki dealer i go!
i had the very same problem and gave up. Got all the screws out but couldnt slide the shaft out.
