Can you not reuse the plates. This seal really only keeps the crap out as there should only be grease in it. If you have oil then I would assume the shaft seal has failed. As far as I know these parts are suzuki only unless you buy a kit from abroad.
SJ 413 ball joint seal and felt needed-cheaper than Suzuki?
Re: SJ 413 ball joint seal and felt needed-cheaper than Suzu
Is this any help?
http://cgi.ebay.co.uk/Suzuki-Samurai-sj ... 2a108be49c" onclick="window.open(this.href);return false;
But as Darrel said, if you have oil comming out you may need to replace the shaft seal. I bought a full rebuild kit from America, but i wouldn't recomend it as it cost a absolute fortune .
- Tramp
I always assumed the hub aught to have oil in so when i did overhaul it I filled it with landrover one shot hub seal grease, If id have read the manual I'd have realized it only needed grease! grrrrr
I bought a full axle rebuild kit off eBay from Australia cost about £80. It included felts seals and the steel plates as well as king pin bearings. The axle was in a state tho, and needed everything changing, definately worth the effort tho as now they are clean and dry. Also worth remembering that the felts and seals act as a steering damper and if worn can cause issues with stability at speed.
sj413 samurai, pro comp springs, shackles, braided hoses, 10.5x31's bumpers, buckety seats and the best mod in the world a diesel lump (vauxhall 1.5td)
