various handbrake cables
Hi, does anyone know where i can get a handbrake cable for a Spanish,1993 sj samari sport, It is the sort that goes into both rear brake drums and is driving me nuts. I tried unipart and they sent the wrong bit, and ebay, wrong bit again.Thanks, Rich.
FOR SALE.... various handbrake cables.
Re: various handbrake cables
i gave up trying to get a handbrake cable and got a 410 transfer drum brake instead
All the diagrams I can find show this setup
O and
O and
- handbrake 1.JPG (128.12 KiB) Viewed 9104 times
Thanks for that, hav'nt got one of those yet, but its not the one,Darrell wrote:All the diagrams I can find show this setup
O and
im having the same problem cant get hold of a cable any where they all say go to main dealer :s
and when you put drum on the t-box how do you ajust the rear shoes because the hand brake normally does this :s
1992 Suzuki SJ 413 samurai,TURBO,Webber carb,2" calmini shackle reversal kit,32mm wheel spacers,maxxis 235/75/15 mud tires,vitara alloys,swift gti interior,1"lift springs,heavy duty transfer box mounting bracket.
1986 land rover 110 ,boost alloys,bfgoodrich mud terrains,a bar,spot lights,
Its the handbrake cable that splits into two a few inches away from the lever, then it has two cables... one going to each wheel.
I know cos I have it... I only have 1 spare but I cant get rid of it until I've got a transfer brake I'm afraid :(
Been hunting again, found this setup fitted to some models. Cables are listed as LH 45096-84c00 RH 45068-84c00
- suzuki-cat.ru.gif (27.45 KiB) Viewed 9092 times
[quote="Darrell"]Been hunting again, found this setup fitted to some models. Cables are listed as LH 45096-84c00 RH 45068-8Thanks,
Thanks, thats the one. I will now be able to show sellers exactly what i want. Can you tell me where they are listed under those no's, Your help is very much apprecited. Rich.
From a russian website of all places
http://translate.google.co.uk/translate ... rmd%3Divns" onclick="window.open(this.href);return false;
Don't seem to be able to link to the correct page
So select- samurai sj 413 - modification 49 - suspension/brakes - parking brake
- Ginger_boy
Hi
I had exectly the same prob 4 years ago when one of mine snapped. Only place I found i could get them was main dealer but that after several attempts with different pics i got a pair. I have an old one i think its drivers side if that helps
