Biggest on stock
charger
Biggest on stock
Post by charger » Thu Jul 14, 2011 12:39 pm
Can you get mud tyres for the SJ without any lift, I am now running 195/80/15
What other size can you run with stock suspension
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Re: Biggest on stock
Post by twiss » Thu Jul 14, 2011 1:33 pm
You could do 215s, or maybe 225s but they would be very tight.
You definitely couldn't fit 235s on a stock sj...
Post by ScottieJ » Thu Jul 14, 2011 3:02 pm
You might be able to fit 235s if you redrill the spring perches and plates to move the axle 1" forward? maybe??????
Post by Edweird » Thu Jul 14, 2011 9:00 pm
If you're moving the axel forward, wouldn't you want to take the front bumper off, or at least trim the ends off it?
Post by twiss » Fri Jul 15, 2011 12:32 pm
Yeah you will ... I think 235s are quite tight on the standard bumper even if the truck has a bit of lift
charger
Post by charger » Fri Jul 15, 2011 12:58 pm
195/80/15 looks quite a common size & quite a few Muds available in that
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Post by twiss » Fri Jul 15, 2011 1:15 pm
Yeah they are the standard size for an SJ...
215s were available as an optional extra from the factory, so they will definitely fit!
Unless it's powersliding you're after, I'd go for the slightly bigger tyres. You'll get more grip in the muddy stuff!!!
(Saying that, I can powerslide on the 235s in the wet)
Post by Edweird » Fri Jul 15, 2011 4:42 pm
I can get sideways quite easily in the wet. On roundabouts, downhill on overrun, uphill under power. I think it's because of the fact my rears are old, hard, A/T tread Dunlops, and the fronts are modern road tyres.
charger
Post by charger » Mon Jul 18, 2011 12:45 pm
twiss wrote:Yeah they are the standard size for an SJ...
A 215/80??
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Post by twiss » Mon Jul 18, 2011 1:20 pm
Ahh sorry I meant 205/70
I don't think 215/80s would be a huge amount bigger than your 195/80s. How much space do you have around the arches?
