fog wiring?
Henry
fog wiring?
Post by Henry » Sun Jul 17, 2011 5:17 pm
Anyone have a diagram? 8-)
Re: fog wiring?
Post by Darrell » Sun Jul 17, 2011 7:50 pm
You called ..................
Headlight foglight.jpg (268.3 KiB) Viewed 7124 times
Henry
Re: fog wiring?
Post by Henry » Sun Jul 17, 2011 9:06 pm
Is that for the rear darrel? I could just do with knowing what colour the wire is :twisted:
Re: fog wiring?
Post by Darrell » Sun Jul 17, 2011 9:11 pm
Yes the rear.
One green with blue tracer. Switched live.
One green with black tracer. Switched earth.
Switched earth because the foglight will only work with the headlights on.
Henry
Re: fog wiring?
Post by Henry » Sun Jul 17, 2011 9:15 pm
so do they both go to live?
Henry
Henry
Re: fog wiring?
Post by Henry » Sun Jul 17, 2011 9:59 pm
just been for a look, i have 2x grey/green trace wires coming from 1 spade on the switch and one grey/green trace by the lights. So put that to my fog job done?
Re: fog wiring?
Post by Darrell » Sun Jul 17, 2011 10:29 pm
I have no idea.
Why the hell didn't Suzuki just stick too the same colours, it would make life so much easier.
I believe you have a spanish one and my diagrams are for jap crap :argh:
Henry
Re: fog wiring?
Post by Henry » Sun Jul 17, 2011 10:41 pm
Yerp im on Spanish.
When i get my undicator stalk ill turn it on and pop the multi meter on it :salute:
Re: fog wiring?
Post by Darrell » Sun Jul 17, 2011 10:45 pm
Henry wrote:just been for a look, i have 2x grey/green trace wires coming from 1 spade on the switch and one grey/green trace by the lights. So put that to my fog job done?
Probably not that easy, That may well be the switched live for the foglight.
The earth wire for the fog light comes from the headlight switch but also goes to the foglight switch to make the warning light come on.
If you earthed it direct it will work any time the fog light switch is operated and I would assume this is not correct for the MOT.
Re: fog wiring?
Post by Darrell » Sun Jul 17, 2011 10:57 pm
As you said get the meter on that wire and see if it's switched live or not, but there should be another free wire at the foglight if your lucky.
