drill out the spot welds to remove the original arch mount and then weld it back on using the holes you just drilled outChristoff wrote:No a local supplier called Bodicar, also got the same prices from another local called Autorads. They must have the same book
Not bad prices but id need to fabricate a way of fixing the rear arch flares on if i get 410 rear wings
Samurai body parts, prices on last page
Re: Samurai body parts, prices on last page
Yeah is it called plug welding?
What are the odds I remove the arch and there's no metal left behind it though? I bet that lip is quite badly corroded.
you can see how bad they are from the inside. where the inner arch meets the wing it forms a V shape which will probably be rotten.
Do they do front wings? I'm thinking of just cutting my rotten sills out and putting some box steal in and making some rock sliders.
