LEAKS....
Russ24
LEAKS....
Post by Russ24 » Mon Sep 05, 2011 9:35 pm
good evening everyone.
this is not a problem solving thread, i know whats wrong. but i want some pointers.. as im doing some repair work... 'while im there' what else should i do~? to save having to do it later.
my front axle is leaking. both ends. from the wheel hubs. axle greese and transmission fluid.
so im guessing the drive shaft oil seals have given up.
the felt bits on the wheel hubs have also given up.
anything else i should change while im in there???
thanks.
where can i get the felt's from?
:russ:
Re: LEAKS....
Post by Darrell » Mon Sep 05, 2011 9:46 pm
King pin bearings
You can get cheaper bearings than this but I wouldn't.
Good price for 2 Koyo 30302 and a seal
http://www.bigjimny.com/store/index.php ... -/p_6.html" onclick="window.open(this.href);return false;
Have fun :thumbup: stinking ,filthy job by all accounts.
Front Hub Numbers.jpg (174.16 KiB) Viewed 6641 times
Re: LEAKS....
Post by turbo-tom » Mon Sep 05, 2011 9:53 pm
while russ does his can you do mine :lol:
Re: LEAKS....
Post by Darrell » Mon Sep 05, 2011 9:58 pm
Who me ??
"O" No :tongue:
Re: LEAKS....
Post by turbo-tom » Mon Sep 05, 2011 10:04 pm
thats allright i meant russ :lol: :lol: , cant get your diagrams dirty ;) :P (joking ;) ) ,
anyways russ likes playing with big smelly dirty things ;)
Russ24
Re: LEAKS....
Post by Russ24 » Mon Sep 05, 2011 10:19 pm
turbo-tom wrote:thats allright i meant russ :lol: :lol: , cant get your diagrams dirty ;) :P (joking ;) ) ,
yeah that reminds me hows your mum? :p
:russ:
Re: LEAKS....
Post by turbo-tom » Mon Sep 05, 2011 10:21 pm
shes doing well shes at work clearing up shit , piss , n puke , and chasing after mental people ;) at the moment :lol:
Russ24
Re: LEAKS....
Post by Russ24 » Mon Sep 05, 2011 10:24 pm
Darrell wrote:King pin bearings
cheers btw.
kingpin bearings. good idea. with oil seal. good good.
i think i have seen the felt and plate kits on the bay of E.
i have some bog stock castrol LM grease.. will that do for the bearings and other bits like regreasing the CV joints.?
:russ:
Re: LEAKS....
Post by twiss » Tue Sep 06, 2011 12:15 am
Its dead easy to repair the seals and felt! Even you can do it Russ :P
Russ24
Re: LEAKS....
Post by Russ24 » Tue Sep 06, 2011 9:25 pm
twiss wrote:Its dead easy to repair the seals and felt! Even you can do it Russ :P
i know i can.
when i did the wheel bearings i wish i had done them then.
anyways unrelated topic.... friend has offered me a 88 reg 410. starts runs and failed its mot on hazards and indicators not working or too fast.. rust / damage / corrosion near chassis mount and a seaized caliper....
worth it? its basically standard.
:russ:
