Virtual Lift
- lazy rambler
- Can I have a tow
Virtual Lift
This is probably gonna make my seem a bit thick, but I've seen in Scottie J's signature, and googled it but I can't figure out what a virtual lift is. Can anybody shed any light on this for me?
Re: Virtual Lift
it's not really a lift of any kind, it's chopping out the arches to fit bigger tyres.
like this
You can actually cut out enough to run 35" tyres with no lift
like this
- lazy rambler
- Can I have a tow
Re: Virtual Lift
ahh that makes sence, all I have to do now is learn to
Re: Virtual Lift
Lazy rambler said..This is probably gonna make my seem a bit thick, but I've seen in Scottie J's signature, and googled it but I can't figure out what a virtual lift is.
Jep, me to, but guess what that's what I've started to do to mine,without knowing how good a mod it is or what it's called.
My SJ's at the second photo stage just a bit different shape as I'm fitting LR flexi arches.
Virtual lift
Hi can somebody explain what is a virtual lift please?
Seen it mentioned a few times and as im tackling some bodywork rust issues soon i understand that i should be thinking about doing this to mine
ta
ta
Re: Virtual lift
We'll wait for Scott to reply to this one, he's got the virtual lift
Re: Virtual lift
Christoff wrote:Hi can somebody explain what is a virtual lift please?
ta
I merged this topic with the last person to ask this It was in the wrong section, thats why you probably didn't see it so I also moved it into bodywork & Trimtwiss wrote:We'll wait for Scott to reply to this one, he's got the virtual lift
Personally If I was going to do a virtual lift again I would probably make complete new inner arches for the rear like how Shuduck has done his
note: he also raised the floor, you dont need to do this unless you want to raise the fuel tank.
Re: Virtual Lift
Very cool. Some of you guys do some extreme stuff im impressed
Re: Virtual Lift
I'm doing a virtual lift on my SJ but the boot floor has a thousand patches poorly welded to it.. So.. I was thinking about replacing the boot floor with a dam great sheet of checker/chequer plate??
Any thoughts on this??
Re: Virtual Lift
Have you thought about buying a new rear floor?
