Scottie's Zuke. Blue
Re: Scottie's Zuke
Post by ScottieJ » Tue Sep 27, 2011 12:22 pm
sam16v wrote:nice work as usual Scottie. Lots of attention to detail. Inspires me to get cracking on mine, Keep it up!
Cheers matey :hands:
dan_2k_uk wrote:I hope you are aware that this is now a race?!?
Well you best crack on then Dan, my body went back on last night :thefinger:
However I now need to either lower the back or raise the front as it's not sitting flat with the extra weight of the engine and transmission up front
Re: Scottie's Zuke
Post by twiss » Tue Sep 27, 2011 4:57 pm
It's a 3-way race... can I learn to weld and fix my floor before scott and dan finish their zooks?
Probably :P
Edit: I dunno how fast you work dan, but if you're like scott you'll be months yet ;)
Re: Scottie's Zuke
Post by ScottieJ » Tue Sep 27, 2011 5:09 pm
:blah: I'd like to see how long it'd take you to do a ground up rebuild with lots of mods :thefinger: how longs yours been off the road eh needing only a few simple repairs :tongue:
Re: Scottie's Zuke
Post by twiss » Tue Sep 27, 2011 5:22 pm
Only just over 6 months lol...
I have replaced the steering bar, the kingpins, the felt pads and oil seals, the sump gasket, the brake hoses, the calipers, the pads, the rear shoes, readjusted the rear brakes so they actually work, tidied the wiring in the engine bay, put a new snorkel on and re-wired some of the lights... I also fixed the interior light!!!
So it's not just been sitting there :P
The only bits I haven't done is the welding... and that's more because I'm cheap rather than lazy!
I don't see why I should spend £300 getting it welded when I can use my free time and some scrap metal to do it for nothing!!!
Team Pink
Re: Scottie's Zuke
Post by Team Pink » Tue Sep 27, 2011 6:15 pm
twiss wrote:Only just over 6 months lol...
That is more or less prep between races + a full nuts and bolt check front to back and repair any breakages. 2 weeks worth at the most, what have you been doing for the other 5 1/2 months
:lol:
rockwatt
Recommended Trader
Recommended Trader
Re: Scottie's Zuke
Post by rockwatt » Tue Sep 27, 2011 9:51 pm
:lol:
I did a coil job in 4 weeks !!!! So what you bleeting at twiss? Just get stuck in.
Rocklobster gears , refurb cases , dual cases , su manifolds , jimny rocklobster conversions inc speedo drive, t/case heavy duty mounting arms and rock buckets, bespoke fabrications and machining,
Contact me for details.
Russ24
Re: Scottie's Zuke
Post by Russ24 » Tue Sep 27, 2011 10:11 pm
:lol:
am i in on this race.. i always start by drinking tea and spending 2 hours on you tube
:russ:
Re: Scottie's Zuke
Post by ScottieJ » Wed Sep 28, 2011 12:40 am
:lol: :lol: Of course you can Russ :hands:
I think we all know that it's hard to find the time to get work done on the truck sometimes, no one on here can beat my housemate though, that range rover you see in my pics has had a blown transfer box since the 2010 difflock to the core weekender and he only decided to get the transfer box out 2 weeks ago :lol:
Re: Scottie's Zuke
Post by ScottieJ » Wed Sep 28, 2011 1:07 am
I almost forgot! Pics :thefinger:
Twin electric fans (need to fix the wires on one though)
Nice and Flat belly 16" from the floor
Front prop clearance
Tcase tucked nicely into the gap
and last but not least :guns: it stands 5ft10" tall, pretty low for 33s!
Re: Scottie's Zuke
Post by twiss » Wed Sep 28, 2011 9:36 am
I'll have you know I've spent the last 5 1/2 months trying to find someone to do my welding for free :P
Unsuccessfully I might add!
