SUZUKI SAMURAI 1300 VIBRATING PROBLEM
molehill
Re: SUZUKI SAMURAI 1300 VIBRATING PROBLEM
Post by molehill » Thu Oct 13, 2011 7:24 pm
When I bought my little baby it shook like hell - found the rear prop u.j. yokes out of alignment on the sliding joint, might be worth checking your front prop if it's been apart.......
Post by ScottieJ » Thu Oct 13, 2011 11:03 pm
molehill wrote:When I bought my little baby it shook like hell - found the rear prop u.j. yokes out of alignment on the sliding joint, might be worth checking your front prop if it's been apart.......
Yeah thats a good call! If they are out of phase it will have some bad Vibes as the UJs will be working against eachother
madman ray
Post by madman ray » Fri Oct 14, 2011 12:10 am
think ive found the problem..the gear box mount has broke on the rubber part
Post by ScottieJ » Fri Oct 14, 2011 12:25 am
I should have a gearbox mount in the workshop, ill have a look for you
