Quick question
Quick question
Went to the anus this morning I'm about to strip the heater box down and clean it
There seems to be moisture around the footwells and back of dash at bottom. Around the pedals, heater box and bulkhead. Where does this come from?
Is it just condensation from been stood all night and then warmed up in this mornings sun ?
Or is it because there might be defective door seals / bulkhead grommets or the holes iv left in the arches ????
Ta
Ta
Re: Quick question
I've had these drains block with leafs before now making the whole airbox fill with water. When I went around a bend it would pee on my feet
- drains.jpg (18.37 KiB) Viewed 7592 times
Re: Quick question
Hi darrell. Right on the money there my friend
I had a poke around there this afternoon and found those drains were both blocked.
When I disconnected them from the heater box inside I could feel more crap inside so I fished as much out as I could. I wanted to remove the whole thing and clean it properly but could not get the dash out. The heaters all work fine and the drains are now clear so I guess that will do for now.
Sometimes if I turn the fan up to max I get a bit of dust in my eyes but it's only for a second
- Edweird
Re: Quick question
I'll check those in mine too, because after rain I often go to my truck and find a puddle on the floor mat in the drivers footwell.
Re: Quick question
Where does all the crap come from that ends up in the blowing unit thing? Where's the pick up?
Re: Quick question
the vent in front of the windscreen i tape mine up when off road to stop the crap getting in
Re: Quick question
Goes in hereChristoff wrote:Where does all the crap come from that ends up in the blowing unit thing? Where's the pick up?
- DSCF2223.jpg (178.73 KiB) Viewed 7556 times
Re: Quick question
could use something like this http://www.ebay.co.uk/itm/Suzuki-Samura ... 600wt_1396" onclick="window.open(this.href);return false;
Re: Quick question
sorry double post
Re: Quick question
Gaffa tapes as good as anything for me I think. Im not a serious off roader just yet
