Right so im changing my clutch on my sj410 (85) and upon removing the clutch the thrust bearing fell out and it seems i have lost one of the retaining clips (little u shaped buggers that go round the fork) so this is my first question where can i get one?
now the new clutch (valeo) is exactly the same however the thrust bearing is different, mine has 2 lugs with a hole for the retaining clip and a big bearing in the front. The new one has 2 thinner lugs that bend 90degrees one has a hole in it with the bearing built in and just a thin ring showing for the clutch to turn on.
Whats going on lol
thrust bearings
Re: thrust bearings
Been having a look round to see what info I could find and have saved these diagrams (yay, more diagrams )
It appears the early 410 has a different shaft and release bearing.
- 410 normal.JPG (87.58 KiB) Viewed 4536 times
- 410 82-84.JPG (122.48 KiB) Viewed 4482 times
Re: thrust bearings
Suzuki only for the springs I guess.
- 2.JPG (25.84 KiB) Viewed 4530 times
- 410 82-84.jpgdr.jpg (109.73 KiB) Viewed 4530 times
- 1.JPG (24.41 KiB) Viewed 4482 times
Re: thrust bearings
That's ace lads mines deffo an early type looks like a trip to zooki for some clips later and whack it all back on the old bearings fine do I'll just use that then I've got a new bearing if I ever change box
Thanx for the great help once again
