Team Pink SJ
Re: Team Pink SJ
I've never known anyone bed so many SJ axles they just aren't up for comp safari in stock form eh Looks like the final incarnation of axle bracing will be almost bomb proof if you haven't managed to bend them
Re: Team Pink SJ
Scottie, since fitting I have not had to worry about what I hit, TBH I think I would break a spring before I bend an axle.
After the winter rebuild I had decided to do at least 5 races with the AWDC, for once many of them were close to hand, or at least as close as they were likely to be to the West coast of Wales! 1st event did not according to plan (what did I say earlier about a pattern) On lap 1 the clutch started to slip, I nursed it until the last lap, however in the meantime the gearbox mount broke meaning that gear selection was a bit hit and miss. On the last lap I slotted 5th instead of 3rd, the clutch was slipping so much that I did not notice and I lost all drive 1/2 mile from the finish. As I had completed over 75% of the laps I classed as a finisher.
I used a Petroworks clutch and managed to get one over from the States within a week so had it fitted before the next race. I cannot praise this clutch enough, without the gearbox mount problem I would have finished the race. As it was I raced for 50 odd miles on a slipping clutch. On removal there was not a single bit of friction material left on the organic face.
I remade the gearbox mount using a spare spring bush to ensure that it would never cause the same issue again.
- gbox mount.jpg (593.76 KiB) Viewed 4422 times
Re: Team Pink SJ
This bit is not in chronological order but will give an idea of where the project stands atm
- oct 3.jpg (252.64 KiB) Viewed 4396 times
- oct 2.jpg (248.79 KiB) Viewed 4396 times
- oct1.jpg (252.06 KiB) Viewed 4396 times
Re: Team Pink SJ
Pulled it out of the garage today to strip out the SJ axles
- oct 11.jpg (659.82 KiB) Viewed 4365 times
Re: Team Pink SJ
looks like an sj hotrod like that Tim
Ooooh I like the sound of part of that sentence as well
