Now lifted before & after
charger
Post by charger » Fri Nov 11, 2011 11:24 am
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Re: Now lifted before & after
Post by twiss » Fri Nov 11, 2011 11:28 am
Hi, that's a very white SJ!!!
How did you lift it up? Lift springs or add a leaf?
The front looks quite a bit lower than the back... maybe worth knocking up some slightly extended shackles so its the same height?
Up to you though!
Post by ScottieJ » Fri Nov 11, 2011 12:28 pm
Looks good, now just needs some bigger boots :rockin:
mathewh11
Post by mathewh11 » Fri Nov 11, 2011 1:47 pm
Looks good kinda like everything white!, bet it's fun to look for in the snow :lol:
matt...
charger
Post by charger » Fri Nov 11, 2011 7:41 pm
twiss wrote:Hi, that's a very white SJ!!!
Up to you though!
Add a Leafs it look more than 2" to me though, the clearance from the ground to sill is over 20". Need rear shocks first then will get new rubber.
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
