paint
Re: paint
Post by dan_2k_uk » Thu Sep 01, 2011 11:48 pm
im working this weekend and going away camping for a week the following so just gunna get what i have done covered up to stop it from rusting.
did a bit today before trying out my new tent.
that red oxide primer i "borrowed" from work is quality and it turns out its was totally full. all 5L :lol:
Re: paint
Post by mike harris » Fri Sep 02, 2011 9:36 am
When I sprayed my truck, I used a layer of red oxide, that was just put on after it was blaster, then a layer of isolayter, that is key if you want the paint to stick and if your terrible at painting like me !!!!
Then I used three coats of mercades signal two pack MIPA red,
Two pack is the best paint as it goes so hard !!
The first time I sprayed mine I used synthetic paint and it went horribly wrong !!
Mike
Re: paint
Post by ScottieJ » Fri Sep 02, 2011 10:26 am
:lol: Don't say that mike I'm using synthetic for mine again! It worked fine the first time round so hopefully it will again! :S I've ordered mine in a kit though so all the thinners and primer are 100% compatible (I hope :lol:) It's quite strange that yours reacted so badly with synthetic there isn't many types of paint it will react with as a top coat :er: however it will react really bad if you use a cellulose based paint on top of synthetic :lol:
only reason I use synthetic is that it's nice and easy to touch up.
Re: paint
Post by dan_2k_uk » Fri Sep 02, 2011 11:01 am
spray! pffft! :thumbup:
Re: paint
Post by ScottieJ » Fri Sep 02, 2011 11:21 am
dan_2k_uk wrote:spray! pffft! :thumbup:
I haven't yet decided whether or not to spray this time or roller mine again?
Either way my paint has arrived now :guns:
Re: paint
Post by ROBBIE » Sat Sep 03, 2011 9:39 am
satin black rattle cans always got 1 in the SJ in case of scratches :hahaha:
dougsj410
Re: paint
Post by dougsj410 » Wed Nov 16, 2011 1:33 pm
I use rustoleum, Just finished painting my camper in in with a roller and with a bit of finishing most people don't believe its not sprayed...
One tin at £25 will do the whole truck and no need to prime. Only thing is it takes a few days to fully harden. I put it on with a B&Q gloss roller.
You want combicolor metal paint. - i buy it from here.. rustoleum.co.uk
Doug
