got a 2" lift, standard 410 engine/running gear etc... anyone know what is the best tyre size for this set up and what tyres shall i get?
need to be fairly good on road and not too expensive! thanks
tyres
Re: tyres
only shackles at the moment, mainly because my old ones were knackered and i'm saving for a proper lift kit anyway!
Re: tyres
The option I chose was cutting down the gay extended shackles so they give about an inch of lift, then stuck add-a-leaves in.
Gives about 2.5 - 3 inches lift, and I've got wheel spacers as well
Then you can fit 235x80r15s on with no rubbing![:) :)](./images/smilies/icon_e_smile.gif)
Although, it will make it slower so you might want to go with 215s or 225s to keep some of your acceleration
