Exhaust
Re: Exhaust
When I snapped my cherry bomb in half, I bent an existing bit of pipe with an SJ exhaust flange round 90*... then I just bolted it onto the middle section, and it chucks the gas out between the wheel and the wheelarch.
Its well out of the way, but really loud, and wouldn't pass an MOT
Re: Exhaust
Do you have a pic of that?
I'm confident mine will pass it's MOT
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
Re: Exhaust
No I dont have a pic sorry, I do have some badly drawn paint pics though haha
- bentpipe.jpg (2.43 KiB) Viewed 5222 times
- exhaust.jpg (16.74 KiB) Viewed 5222 times
Re: Exhaust
My plan was to cut of the rotten pipe & bolt on the Cherry bomb
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
Re: Exhaust
Something like this? It would be fawking loud!!!!!
- shortcherrybomb.jpg (19.08 KiB) Viewed 5218 times
Re: Exhaust
surely that would be too loud!
i know its not anything like an sj but this is the only thing I could find that was straight through to a cherrybomb that wasnt a massive yank v8
anyway its loud!
Click Here for Youtube Video
Dan
anyway its loud!
Dan
Re: Exhaust
Trust me a cherry bomb on its own will drive you mad after a while, I had a mk2 golf gti front box (pretty much a cherry bomb) and a cherry bomb, it was loud but not too loud and sounded nice. But when I broke the cherry bomb off and had to drive back from Normandy in France I really wanted some ear plugs, the missus and I had to shout to hear each other
Now I'm pretty much going to use a modified full mk2 golf gti exhaust with 3 silencers as loud exhausts just piss you off after a while.
Re: Exhaust
That's why you need the exhaust to be loud only when you floor it
That's why I kept my centre box in, because it keeps it below ridiculous levels while you're under 1/2 throttle
Re: Exhaust
I like a little bit of volume when you floor it but not too much, otherwise when you are driving on motorways / fast A roads it is too loud, I just fitted a standard exhaust to the golf gti and its spot on, has a nice throaty sound when you boot it but isn't too loud when cruising at 70. A nice sounding exhaust is a lot better than a loud one.
Re: Exhaust
See, I like to be able to set car alarms off when I drive past them
