Scottie's Zuke. Blue
Re: Scottie's Zuke
Post by ScottieJ » Wed Jan 04, 2012 11:57 pm
Finally starting to crack on with the SJ again.
I wasn't happy with the 1st shifter set up I made for the twin tboxes so I made my own little linkage for the doubler to give me more room for the SJ tbox shifter. It's not pretty but it works :lol:
New shifter positions
Started the tunnel cover
Thought it would be rude not to test fit the new steering wheel, Thanks Tom :doublethumbs:
Re: Scottie's Zuke
Post by turbo-tom » Thu Jan 05, 2012 9:47 am
glad you got it allright then :doublethumbs: :doublethumbs:
Re: Scottie's Zuke
Post by ScottieJ » Thu Jan 05, 2012 11:25 pm
Cracking on now boys, just need to finish the welding and fit some rivnuts to bolt the cover down, then I can paint the interior :thumbup:
Re: Scottie's Zuke
Post by dan_2k_uk » Fri Jan 06, 2012 12:20 pm
Twin transfer sticks on the sj box and fiddle brakes should make it really confusing.
Consider it an anti-theft measure :thumbup:
chrisj410
Re: Scottie's Zuke
Post by chrisj410 » Fri Jan 06, 2012 3:35 pm
:O that looks sweet man, gonna be a beast :twisted: looks fecking confusing tho lol
Re: Scottie's Zuke
Post by ScottieJ » Fri Jan 06, 2012 3:45 pm
Cheers matey, its not that confusing once you get used to it.
And Dan I'm toying with twin sticks for the SJ case, won't be doing fiddles as this ones road legal and there's a bit of a grey area when it comes to fiddles on a road legal motor :bawling: id need to fit a second set of calipers to the rear axle as well.
Re: Scottie's Zuke
Post by ScottieJ » Sat Jan 14, 2012 9:22 am
Just been doing lots of the small things recently
Got a new aluminum rocker cover for no other reason than because I could :lol:
Cheers Sam16v
Also got one of the mk2 golf headlights in, was a bit of a pain in the ass with the virtual lift, I wouldn't recommend it :lol:
rgonzobull
Re: Scottie's Zuke
Post by rgonzobull » Sat Jan 14, 2012 8:54 pm
Works looking good Scott. How much more work have you got to do on the SJ before its back on the road?
LJ80Q
Re: Scottie's Zuke
Post by ScottieJ » Sat Jan 14, 2012 9:26 pm
Cheers Gonzo
Errrrm :er:
Exhaust
Handbrake
Coolant plumbing
Electric fan wiring
Pass side headlight
Dash wiring tidy up- I'm moving the fuse box
SU carb ( ;) Twiss hurry up :tongue: )
Brake master cylinder seal kit, my dad and I plumbed in all the brakes today but we think the seals have dried out :cry:
Bump stops
Lower shock mounts all round and front upper shock mounts
Paint
Fit seats
Exo cage
I Think thats it bit there's probably more :hahaha:
rgonzobull
Re: Scottie's Zuke
Post by rgonzobull » Sat Jan 14, 2012 9:32 pm
Well its a nice day tomorrow so you should get it all done! Lol. No seriously, its looking good. Bet you cant wait to try it out
LJ80Q
