Project KJA
- ianedwards
- SCUK Addict
Re: Project KJA
Hi,
Does any know how comfy jimny seats are, they look small enough to be a pretty good fit for this project.
Ian
Sent from my iPad using Forum Runner
Ian
- justaddmud
- Can I have a tow
Re: Project KJA
I looked into MX5 seats, they are pretty comfy, small and could have speakers in the headrest
from what i read, the seats are not very supportive (jimny) but have no experience with this
Re: Project KJA
Jimny seats arnt all that, they are firmer than the 1s that were in my SJ but then the SJs were nearly 20 years old and the Jimny only 10
- ianedwards
- SCUK Addict
Re: Project KJA
Hmmm, dunno what quite to do
- ianedwards
- SCUK Addict
Re: Project KJA
Hi, done a bit more today, hung the stripped drivers door, just got to remove the decals. I also stripped the rear axle, only to discover that a few things are required, like new bearings, cylinders, and pads. Everything lol. Never mind. A bit more done. Also started having a look at my winch.
Ian
Cheers Ian
Ian
Cheers Ian
- image-4131749391.png (936.22 KiB) Viewed 7102 times
- image-2156627732.png (964.21 KiB) Viewed 7102 times
- image-3626862848.png (929.55 KiB) Viewed 7102 times
- image-111391426.png (943.23 KiB) Viewed 7102 times
- ianedwards
- SCUK Addict
Re: Project KJA
La la la, should have bought a sand blaster.
Cheers Ian
Cheers Ian
- justaddmud
- Can I have a tow
Re: Project KJA
cleaning and painting is such a long seemingly endless task
but its all worth it in the end, keep up the good work
Re: Project KJA
Yeah cleaning and prepping is such a mundane task
worth it in the end though
- ianedwards
- SCUK Addict
Re: Project KJA
Yea it will be, think I've gone through 5 of the wire brushes that go on a 4 inch grinder. Lol. Coming along tho, back axle is nearly ready to paint.
Ian
Ian
- ianedwards
- SCUK Addict
Re: Project KJA
Yo,
Any one know what size brake pipe and fittings go on a 413,
Suspect it's 3/16 pipe and 10mm fittings but would like to confirm before ordering some bits.
Going to replace the lot while I'm at it.
If any one has changed thiers any info would be cool,
Cheers Ian
Cheers Ian
